bvolcko38 wrote:Pulled the right head yesterday and found 2 leaking exhaust valves, one much worse than the other. Upon careful inspection we found the seats warped, valves were fine. A friend has a seat grinder and we trued the seats. Waiting for parts now.
sonex1374 wrote:Bill,
I had a similar experience years ago with my AeroVee where one pushrod tip was severely worn (ground down actually). After troubleshooting and giving it a good inspection I think there may have been something inside the pushrod that slightly restricted oil flow thru the tube. It wasn't completely blocked (just slightly obstructed), but it was enough to wear the tip. Maybe this just happened to coincide with a soft/bad tip, but replacing the old pushrod with an entirely new assembly solved that particular problem.
Jeff
Users browsing this forum: dreyn96, Google Adsense [Bot] and 19 guests
