JerryCPP wrote:After my Timesert came out with the plug, I made a collar to fit on an old plug to use when installing the Timesert. The collar allows only the bottom half of the spark plug treads to engage the Timesert ; that way I can remove the plug without pulling the Timesert again. Using this modified plug, I can put some torque on the Timesert when installing it. I also used some high temperature Loctite. I think getting the Timesert in tight helps with heat transfer too.
Users browsing this forum: No registered users and 36 guests
