GraemeSmith wrote:Pitch to hold altitude till 80KIAS
WesRagle wrote:Hey Graeme,GraemeSmith wrote:Pitch to hold altitude till 80KIAS
How fast are you abeam the numbers?
Wes
WesRagle wrote:One thing I didn't hear discussed was power settings. I've always been taught to pull power to idle abeam the touchdown point and not to touch it again before landing.
sonex1374 wrote:Flying power-off approaches is fun and helps keep you sharp, but just like in gliders you won't fly the approach without a way to extend your glide. ..... can always turn base a little sooner, keep a little high or close on downwind, and get your flaps in earlier rather than later (so you can assess your glide path and make adjustments before you fall hopelessly below the glide path).
Jeff
GraemeSmith wrote:Ummm..... About 90KIAS
sonex1374 wrote:Flying power-off approaches is fun and helps keep you sharp, but just like in gliders you won't fly the approach without a way to extend your glide. In a glider you start the approach with partial spoilers so that you can clean up as needed to extend. You'll never fly the pattern without keeping options in the bank. In the Sonex you'll want to keep the same mentality. You can always turn base a little sooner, keep a little high or close on downwind, and get your flaps in earlier rather than later (so you can assess your glide path and make adjustments before you fall hopelessly below the glide path).
