Firewall forward help (need photo's and advise)
Re: Firewall forward help (need photo's and advise)
Postby pfhoeycfi » Wed Aug 12, 2020 2:20 pm
I am putting together a list of firewall "stuff" for ordering and was wondering if builders are using 1 or 2 firewall pass thru ducts for the wiring... ie is it better to run the high current conductors thru their own pass thru or will one common pass thru suffice? From the pictures I've seen on here and some of the build logs it appears that a single pass thru for wiring is common.
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby racaldwell » Wed Aug 12, 2020 5:29 pm
Peter,
I am using two pass throughs for electrical, lot is to do with location. Battery & B Lead on lower right and engine sensor wiring upper left. There may be a picture on my EAA project page you could look at.
Rick Caldwell
Xenos 0057
racaldwell
Postby WesRagle » Wed Aug 12, 2020 6:24 pm
Hi Peter,
I used two pass thrus as well. One for power, p-lead, master, starter, ... The other for signal wires. The firewall was penetrated in convenient locations such that the bundles could be routed/secured with cushion clamps bolted on along with the tank straps.
No good pics but ...
You can kinda see the signal bundle pass through in the corrugated/split sheath in this pic.
Power was routed through on the other side.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby NWade » Thu Aug 13, 2020 1:55 am
I am using 2 pass-throughs: One for electrical and one for my throttle & mixture controls. All of my power wires are protected with a fuse or a circuit breaker, so as long as there's not chafing I am not concerned about separating the wires into multiple passthroughs. Each additional passthrough is not only a potential for cockpit flames and smoke in the event of a fire, but its also a pathway for carbon monoxide, a place where riveted attachments/sleeves can fail, etc - so I'd rather have the fewest number of them possible.
With the electrical pass-through (and indeed all electrical wires) I'm using aircraft-grade Tefzel wiring of the appropriate gauge for the current and wire-length. To help prevent chafing against each other the wires are secured with a combination of self-fusing silicone tape and zip-ties. Where they pass through the firewall I am using an Aircraft Spruce kitthat has you wrap the wires in a firesleeve (to prevent wire-to-metal rubbing),and then an outer wrap of firesleeve with fire-caulk helps secure the whole assembly (wire bundles and stainless-steel pass-through) into a semi-sealed unit.
Here are a few pictures...
Stainless-steel pass-throughs are at the lower-right of this image: https://1drv.ms/u/s!ApMKXiyfUEPR0X6vbcPaLKmih4tl
Wiring and inner firesleeve in place, as viewed from the "cold" side of the firewall: https://1drv.ms/u/s!ApMKXiyfUEPRg7IIB3UNi4RtyiKILg
Outer firesleeve and caulking on the "hot" side of the firewall: https://1drv.ms/u/s!ApMKXiyfUEPRg7IGKnRw5XcmodJUKA
Hope this helps!
--Noel
Sonex #1339
NWade
Postby pfhoeycfi » Thu Aug 13, 2020 7:41 am
Thanks all! Perfect....
peter
Peter Hoey
pfhoeycfi
Users browsing this forum: petep and 55 guests
