What are your Onex numbers?
Postby gcm52 » Mon Aug 10, 2020 2:27 pm
I am about to test fly my Onex and I am curious about the kinds of numbers previous Onex flyers are seeing. Would you post your numbers for the following?
(Empty weight)W&B nose wheel weight
(Empty weight)W&B right main wheel weight
(Empty weight)W&B left main wheel weight
Empty weight CG in inches from datum
Stall with flaps
Stall without flaps
Best Glide speed
Typical rate of climb
75% power cruise
WOT cruise
Typical take off distance
Typical landing distance
Thanks in advance!
George
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: What are your Onex numbers?
Postby WesRagle » Tue Aug 11, 2020 3:02 pm
Hi George,
I too am very interested in Onex data. I'm just now getting to the point that I can start gathering performance data so I don't have much to offer. A lot of the data you are asking for depends on technique/calibrated air speed/density altitude/wind speed. At present I can't provide data based on any of those criteria. I have about 30 landings and they have all been different :-) I need to check my airspeed calibration first. I'll edit this post and add information as it becomes available. I hope others will join in.
P.S. I don't know why the columns won't display properly. I cut and pasted from a Word document and removed tabs and replaced them with spaces manually.
W&B
April 29, 2020
Data recorded with top longeron level
Datum 50.875 inches forward of wing leading edge (Spinner Tip).
CG Range 60.875 - 66.875 inches aft of datum.
Empty Weight includes 3 quarts of oil
Weight Arm Moment
Left MLG 309.5 53.25 16480.875
Right MLG 305.0 53.25 16241.25
Tail Wheel 24.0 198.5 4764
Total E.W. 638.5 58.71 37486.125
E.W. CG 58.71
Typical effect of temperature and pressure altitude on takeoff performance and climb rate (Koch Chart).
Typical take off distance (Tentative) Zero Wind seems to be about 1000 ft. at ~ 3000 ft DA. Right at the touchdown marking on the runway. Slow throttle advance and no technique :-)
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Gordon » Wed Aug 12, 2020 9:52 am
Hey George.........
I can give you some of the specific "numbers" you are asking for if you want to email me.
gdbaxter78@gmail.com
I have the same engine as Wes Ragle......the Hummel 2400 85 hp. and have been flying mine for 2 years.
As a general comment .....my performance numbers exceed the factory numbers, both in climb rate and top speed, likely due to a bit more horsepower from the Hummel. I have the full length wing tips and the stall speed is even lower than "factory specs".
This is NOT a cross country airplane (my opinion) nor was it meant to be. It fills "the mission" it was designed for very well and in that regard I am happy with it.
An autopilot would be a definite asset in a Onex......I don't have one.
Gordon.........Hummel 2400........Onex #0024 taildragger
Gordon
Users browsing this forum: No registered users and 34 guests
