Rofomoto wrote:Not at my plans right now but might be the 1/4” spar alignment hole
Frankart wrote:I just noticed something else. The solid rivets going through the spar can and through the main web at each wing station does not get updrilled to final size yet per plan sheet W08. I understand not riveting these, but shouldn't the hole be updrilled to final size so it can be deburred while I have everything apart?
sonex892. wrote:Frankart wrote:I just noticed something else. The solid rivets going through the spar can and through the main web at each wing station does not get updrilled to final size yet per plan sheet W08. I understand not riveting these, but shouldn't the hole be updrilled to final size so it can be deburred while I have everything apart?
For this second question, I think you mean the rib stations?. Check the notes but from memory the ribs are riveted to the spar with 1/8" pop rivets not solid 5/32".
Steve
Sonex 892
Frankart wrote:sonex892. wrote:Frankart wrote:I just noticed something else. The solid rivets going through the spar can and through the main web at each wing station does not get updrilled to final size yet per plan sheet W08. I understand not riveting these, but shouldn't the hole be updrilled to final size so it can be deburred while I have everything apart?
Steve
Sonex 892
You’re right. I meant rib station.
Thanks for the help.
Rynoth wrote:Rofomoto wrote:Not at my plans right now but might be the 1/4” spar alignment hole
Same, and I think this is correct. Those holes don't get rivets at all, they are only there for the wing rigging process.
