by jeff0196 » Wed Aug 05, 2020 7:10 pm
All Waiex pilots,
How do you set and check your WIX-C04-02 Aft rudder cable tension?
-Hand check, feels good
-Tension meter
-Other
If you set it with a meter, what value do you use?
Just to clarify, this is the cable between the WIX-C02-02 mixer assembly and the WIX-T03-01 Rudder. This tension is independent of how hard you push your feet on the pedals.
Due to the mixer assembly design/geometry, the tension also changes as you move the elevator control forward (nose down) and back (nose up).
When I put a tension meter on mine it only takes one turn of the adjustment clevis to make a big change in tension, example:
Stick forward - cables have 22.5 lbs
Stick aft - cables have 27.5 lbs
Then remove bolt, turn one half turn tighter on one cable only
Stick forward - cables have 27 lbs
Stick aft - cables have 35 lbs
Stick forward - cables have 30 lbs
Stick aft - cables have 55 lbs
Jeffrey W
Waiex 0196
AeroVee Turbo
