by CaseyCooper » Thu Aug 20, 2020 1:05 pm
So I have a 912 sitting in my Sonex until I get mine in the mail. For now I’m just using it for fitment of parts so when I receive my engine, it should be plug and play! But in the meantime I have run into some hurdles but nothing that can’t be fixed. One issue is my prop flange is a little low in my cowl, but with some persuasion and effort, it’ll work fine. My major problem is that at the back of the engine, the water pump has several outlets. One of which basically rests on the motor mount which means I can’t get a hose on, if I could it wouldn’t last long, and the outlet would likely break off or develop a leak. With that being said they are pressed and glued in. However all of them are in the same position from the factory. I may be able to remove, reorient, and reinstall to help save it. I talked to Mark at Sonex and helped me with what information that he had, very nice and helpful guy. But I found out Sonex has never installed a 912, and has only drawn up the mounting system in cad to satisfy customers who want to use the engine. So, with that being said, there are some hurdles to be overcome but nothing crazy, just like any aircraft build. Here is how it sits currently. I’ve been busy installing the firewall items, wiring,mock up exhaust, and ideas for radiator locations. I will keep posting progress as it comes.
- Attachments
![FFA186BA-DC8B-4B12-AEF2-883A6CC5F261.jpeg (1.17 MiB) Viewed 49429 times FFA186BA-DC8B-4B12-AEF2-883A6CC5F261.jpeg](./download/file.php?id=3128&t=1&sid=b25e28367390e0a16c01e03d8487a1f2)
![41E61A7A-6F0B-4B83-BE66-3F44EB6F1ECB.jpeg (1.29 MiB) Viewed 49429 times 41E61A7A-6F0B-4B83-BE66-3F44EB6F1ECB.jpeg](./download/file.php?id=3127&t=1&sid=b25e28367390e0a16c01e03d8487a1f2)
![C382506C-51CD-4624-AF84-360F9D1FB9B1.jpeg (1.54 MiB) Viewed 49429 times C382506C-51CD-4624-AF84-360F9D1FB9B1.jpeg](./download/file.php?id=3126&t=1&sid=b25e28367390e0a16c01e03d8487a1f2)
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
