lutorm wrote:I'd also like to stop wasting 1 out of my 10 precious alternator amps on the master contactor. There are solid state "relays" that use essentially no current, something like https://www.mouser.com/ProductDetail/Cr ... 7kvuhYo%3d. Anyone tried this route?
The thing you have to watch for with solid state devices is that they're sufficiently protected from voltage spikes, these have maximum ratings of at least 50Vdc, but it would be possible to add an extra overvoltage protection on top.
racaldwell wrote:Hi Bryan,
How does the shaft for the battery switch get around the fuel tank? I don't have a front fuselage yet so I can't see for myself. I am contemplating the Flaming River battery switch that comes with an extension handle. But I already have a Sky Tek master contactor in the hangar that I am tempted to use out of simplicity sake. The one in my RV-6 has been holding up for almost 18 yrs & 960 hrs.
Still trying to finalize my power circuit.
Rick
Xenos 0057
inventor wrote:I don't understand why anyone would want to build a single point of failure into their electrical system
[/quote]NWade wrote:As an IT professional I spend a lot of time thinking about redundancy and points of failure. I see the sentiment quoted above on the Sonex forums a fair amount and it baffles me because there are *lots* of "single points of failure" throughout the entire electrical system for most aircraft; at least until you get up to Biz-jets and Airliners.
inventor wrote:...[snip] I have had a lot of failures with these contactors in liftgates, boats and in a jeep ... [snip] ... I would suggest using fuses or circuit breakers on all loads and use a contactor in series with the starter to guard against a short in the starter system if that is a worry.
Users browsing this forum: Google Adsense [Bot] and 1 guest
