WaiexN143NM wrote:hi steve,
is the exhaust the 3 into one collector ? those 3 slip joints are leaky. dave amsler made some tools to help fix this,
but your’re accross the pond. other suggestions for that joint is fiber wrap (auto parts store) , w stainless wire, and muffler paste.
things i did:
1) sealed wing roots w white caulk silicone (our plane is painted white w stewart white water based epoxy)
2) sealed firewall good , all rivets and corners.
3) filled all rivets on bottom of plane w caulk.
4) make sure you have a fuel. drip pan installed, another area where co could easily enter cockpit.
5) is the area on bottom of cowl opened up enough for good cooling or airflow?
6) sealed area on bulkhead behind baggage area.
good luck, let us know of you success!
WaiexN143NN
Michael1
sonexsteve wrote:I know some time ago there was a fair bit of discussion on the Forum about just this, but I can’t get the search function to work.
inventor wrote:From other posts I have read in the past much CO can get into the cabin from the tail area. Just like leaving the rear window open in a station wagon. Anyone remember those?
Richard
