gammaxy wrote:I think you'll be fine once you trim the turtledeck. It's a pretty common interference. I think the plans dimensions would work if you could teleport the tail into position, but otherwise you have to do some trimming.
This picture's not great, but you might notice I just blended the notch much wider until it fit. Can't tell there was ever a notch there.
sonex1374 wrote:It looks like the very aft end of the fuselage upper longerons might be pinching the vertical stab spar as well. If that happens, you might need to file this down a bit. The very edge could conceivably dig into the vertical stab spar material and cause scratches or stress risers. The plans show this edge getting a slight shaping to it, but at the time it's not clear why. I've noticed this occurrence in several projects and they tend to need a bit more clearance at the time the tail goes into place. Jeff
Users browsing this forum: No registered users and 30 guests
