Canopy latch with automatic lock
Re: Canopy latch with automatic lock
Postby Justin » Mon Jul 06, 2020 6:42 pm
Hi Peter, please put me on the wait list for one as well, thanks.
Justin
Postby mbean » Tue Jul 07, 2020 8:42 am
Peter, I’d be interested in a canopy latch as well.
mbean
Postby stroudj002 » Tue Jul 07, 2020 1:04 pm
Will this latch work with a Onex? If so add me to the list.
stroudj002
Postby peter anson » Thu Jul 09, 2020 8:18 am
stroudj002 wrote:Will this latch work with a Onex? If so add me to the list.
It will work with a Onex but with a couple of small changes. Steve Nelson, Onex flyer from South Australia has supplied me with dimensions and a photo (thanks Steve). It appears that the "D" handle is set much further back on the Onex than on the Sonex so either the handle would have to be relocated forward or an additional pin fitted to the hook angle (the sliding part). There is also not quite enough space for the main body of the locking handle on the forward end of the canopy side rail. The forward end of the hook angle would have to be trimmed by about 2mm. With those two changes it should work OK.
peter anson
Postby pfhoeycfi » Thu Jul 09, 2020 4:03 pm
I'm interested as well...
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby bakerde36 » Fri Jul 10, 2020 8:05 am
I would also be interested in the latch. Thanks Densil
Densil Baker
Sonex 1578, Tailwheel
Hummel 2400, Prince Ptip 54x50
bakerde36
Postby GraemeSmith » Tue Oct 06, 2020 10:00 am
Just in from Oz. 15 days in transit. Nice piece - Thanks Peter!
Graeme JW Smith
GraemeSmith
Postby Matt541 » Thu Oct 08, 2020 7:37 am
Excellent! I'm waiting to build up some extra funds again and then I'll be ordering it and a few other of Peter's accessories. Good to hear that things aren't being held up in shipping anymore as well.
Let us know how the install goes.
Matt541
Postby GraemeSmith » Thu Oct 08, 2020 8:25 am
Took about 60 mins to fit.
My canopy is not standard. I webbed the inside and outside of the tube to rail as I didn't like how fiddly the welded 120 angle tubes were. So one of my webs was in the way and had to be trimmed. I was incredibly lucky. My rivets matched Peter's block holes - otherwise I might have had a rail like Swiss cheese or had to make a new rail.
I riveted the block in place first and used it to find the center for the plexi
Then I step drilled it from the outside.
Dry fit - no sprung center pin in place
I do have a clearance problem with the side panel liner which will need a little "fettling".
Graeme JW Smith
GraemeSmith
Postby GraemeSmith » Thu Oct 08, 2020 8:26 am
In this dry run - I'm not sure how the back of my hand will fare against the knob when on the throttle. Thinking I will reprofile the knob
Ultimately - I'm probably going to replace the rivets that secure the "holder" with through 3mm x 25mm bolts for a solid hold. I've let Peter know about this.
Graeme JW Smith
GraemeSmith
Users browsing this forum: Baidu [Spider] and 63 guests
