Panther16 wrote:Normally only 1 alternator lead will work for a tach pickup. Try the other lead first. I have the same eng D180 combination. I use both tach inputs to the D180. One uses the left mag and the other input uses one alt lead. I also switch the alternator on and off with 2 relays, one for each lead. I also had to change the alternator stator with no problem. My alternator pick up is fused and the mag pick up is not.
Keith Rhode
Sonex s/n 1009
sonex1374 wrote:Kip,
If swapping the tach to the other alternator pigtail wire doesn't help, you might consider placing a resistor inline with the fuse. The resistor will reduce the amount of current that can pass thru the fuse and may drop it back down to a manageable level. I use a 10k ohm resistor in my Skyview tach pickup, and it helps smooth out the tach signal as well (without it the tach was a bit unstable and slow to respond to rapid power changes). Even a small resistor (like 100 ohm) should make a big effect on the current that passes thru that fuse, so if the 10k ohm for some reason doesn't allow a reliable tach signal you can reduce the resistor value until you find the sweet spot that does work.
You can splice/solder a resistor into the tach wire directly, or you can crimp the resistor to a male and female fast-on tab (making a short jumper wire with connectors on each end), then insert it at the existing alternator connector.
Jeff
