Hi All,
I have a question for the Australian builders out there about the upcoming mode S transponder requirement.
As I understand, 2017 is the year when we all have to have switched to a mode S ADS-B capable transponder.
I've also now heard that even though we can still fly with existing mode C transponders till 2017, as of the 6th of February 2014 you can't install mode C transponders anymore, any new aircraft to the register at that point will need a mode S transponder, also if you need to get your existing mode C transponder replaced after that point you will need to replace it with a mode S.
This document seems to confirm this (see first paragraph page 13):
http://www.airservicesaustralia.com/wp- ... RVICES.pdfI'm currently aiming to get my Sonex flying mid to end 2014.
Since Mode S transponders are still ridiculously expensive (not to mention the price of the certified GPS modules), I was intending to purchase a working second hand mode C transponder for now and switch to a mode S when we get closer to 2017. The expectation is they should be dropping in price over the coming years as more manufacturers start producing them for the 2020 rollout in the US.
However, this requirement for mode S transponders on any new installations or replacements after 06/02/2014 would suggest that I will have to get me a mode S straight away (unless I get my plane in the air before 06/02/2014 which is very unlikely).
Is this your understanding as well? Any comments?
