Mike53 wrote:As a retired painter from Ford's I can assure you you made the right decision .I trained many new painters over the years and the learning curve can be steep for some.
Base coat clear coat is different from the old enamel paints in that the base coat is fairly easy to apply but the clear coat is where the problems begin.Not enough and you have a dull finish .To much and you have sags or popping.When applying the clear coat you have to maintain a wet edge till you run out of real estate so your movements have to be planned out well. Two toning helps by splitting the plane up into manageable sections.It will be money well spent :D
Cheers,
Mike
fastj22 wrote:Mike53 wrote:As a retired painter from Ford's I can assure you you made the right decision .I trained many new painters over the years and the learning curve can be steep for some.
Cheers,
Mike
Boy you got that right. Basecoat is easy. But laying down an orange peel free clear coat is beyond my skill set.
I'm still wet sanding and polishing. On a car its not too big a deal, but with all those raised rivets, its a pain in the butt.
Mike53 wrote:Here is a little trick to shorten your work.Get yourself some razor blades and round the corners.Glide the edge along the surface with a forward tilt(the sharp edge is trailing the top edge)Apply a smooth and even pressure and you will remove clearcoat without much effort and at a very rapid rate.All your looking for is removing the heads of the orange peel so don't get to aggressive or you will remove the base coat as well.Start lightly and you will quickly get the feel for how much pressure to apply .It's easy to see when you have removed the orange peel.Also much easier to work into the rivet heads.If done right all you need do after is a quick wet sand and then a polish wheel with a good quality paste and presto :o you will have the shinny surface your after.
Mike.
Mike53 wrote:It matters not the age of the finish as a matter of fact the harder it is the better.At Fords the cars were baked after painting so once they cooled they could be worked on right away if there was a sag.That is the beauty of clear coat.Sags can be razored off and polished .Dirt can be sanded with 600 grit and then polished .Scratches(as long as they were within the clear coat) could be sanded out and again polished.
As I mentioned already ,start lightly till you get a feel for it.I would say the tilt of the razor blade would be about 30 degrees but you will find it easy to determine what's best.
Users browsing this forum: Bing [Bot] and 74 guests
