racaldwell wrote:Art,
This seems like it would be easy to test out the perspective location since Sonex uses pulled rivets. You could punch out the mandrel from a rivet in your location to use as a static port. Connect a tube to the rivet and tee it into the existing static line. Those plastic squeeze clamps can be used to shut off each static source in flight to see if there is a change in readings.
Rick Caldwell
Xenos 0057
We don’t have any recommendation for external static ports. We take static pressure from an open tube inside the cockpit on some of our prototypes. Some people also take it from a tube open to the inside of a wing.
