Onex107 wrote:Just keep in mind fellow aeronauts. The Onex fuel system is designed to only operate correctly in positive G's. Negative G's could cause you to run out of gas and vent liquid from the tank vent.
Onex107 wrote:Onex107 wrote:Just keep in mind fellow aeronauts. The Onex fuel system is designed to only operate correctly in positive G's. Negative G's could cause you to run out of gas and vent liquid from the tank vent.
And I might add, the Onex tank vents out the bottom of the plane whereas the Sonex vents on the windshield and gasoline on the windshield results in cracks. That's why mine needs replacement.
Users browsing this forum: Google [Bot] and 47 guests
