Postby GordonTurner » Wed Apr 22, 2020 10:29 pm
Awesome
Nice work
GordonTurner
Postby Rofomoto » Tue May 26, 2020 10:01 am
Bin a little slow at updates but getting there. Should move to airport soon. (Video because photobucket will not host my pics anymore without a fee)
1735
Longassproject
Rofomoto
Postby sonex892. » Tue May 26, 2020 8:50 pm
Rofomoto wrote:Bin a little slow at updates but getting there. Should move to airport soon. (Video because photobucket will not host my pics anymore without a fee)
Hi Billy. For images I use https://postimages.org/ At least for the time being its a free service. BTW, the plane's looking good.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rofomoto » Mon Jun 01, 2020 3:33 pm
It’s bin exactly two years since my first post to get to this exciting day. Fitting the wing doublers. What kind of gap did anyone leave for the wing root seal? I noticed the plans don’t even cal for a seal there.
1735
Longassproject
Rofomoto
Postby sonex1374 » Mon Jun 01, 2020 3:55 pm
Billy,
The plans simply use the metal wing walk doublers to seal the gap, with only a small (1/16" or so) gap to the fuse. Many builders use rubber channel to create a better seal, but it's not strictly necessary. If you use the rubber seal, the gap needs to be bigger to allow room for the rubber channel material (something like 1/4"). Van's sells a rubber wing root channel that works well, and you'll need one 12' section per wing. You can glue the channel to the doubler with a weatherstrip contact adhesive if you like, but it stays in place pretty well on its own.
https://shop.vansaircraft.com/cgi-bin/s ... oduct=misc
https://www.amazon.com/3M-08008-Black-Weatherstrip-Adhesive/dp/B00598XNT8/ref=sr_1_3
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby Rofomoto » Mon Jun 01, 2020 4:25 pm
Thanx Jeff I trimmed it to the 1/32 the plans call for and its good up to the leading edge skin. Then it gradually goes to 3/16 at the front and I trimmed nothing up there. I guess I’ll trim to your recommended 1/4” and get the seals
1735
Longassproject
Rofomoto
Postby Rynoth » Mon Jun 01, 2020 10:40 pm
For what it's worth, I didn't go with seals. I have a fairly consistant ~1/16 gap. IMO it looks clean from the outside, and I don't have significant draft issues in the cockpit (I think you'll have some flow either way, but it's not like air is blasting in.) If I did it again, I probably still wouldn't do a seal, but there's certainly no harm in doing so.
Postby Rofomoto » Wed Jun 03, 2020 11:36 am
I weighed my plane with the wings on( no ailerons or flaps, bottom skin. Prop and no interior). 538 lbs. I’ll be happy if the cheap scale is even 50 lbs off.
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Jun 24, 2020 5:48 pm
a Lot to do even after the move
1735
Longassproject
Rofomoto
Postby Matt541 » Thu Jun 25, 2020 10:46 am
Congrats Billy!
Rollbacks work great for the fuselage. You beat me to the airport while I'm still polishing. In a hangar no less, they're hard to come by up here.
Can't wait to see her fly.
Matt541
Return to Photo Album
