gammaxy wrote:Dennis,
For testing the triggers, it's probably best to just attempt to use them as intended and see if they output 12v and drop to 0 whenever a magnet moves by. I did this on my workbench, but if you're careful it can probably be done on the airplane. I've never had a trigger failure so tend to be suspicious of the coils.
gammaxy wrote:If they aren't centered very well as you describe, I'd expect that means one would be closer and one further away. The closer one should definitely fire. Another idea you might try is to remove the trigger module and see if you can trigger it manually with a magnet. I can easily trigger it by moving a small neodymium magnet up to the bump on the module.
Users browsing this forum: No registered users and 48 guests
