Baggage Compartment Weight
Postby racaldwell » Mon May 11, 2020 4:51 pm
Finally got around to weighing my baggage compartment and hat shelf.
Overall added about 5 lbs. The hat shelf is to seal off the back of the fuselage and give me space to stick the neck of my classical guitar I travel with if I ever do any X/C's.
The baggage floor structure is easily seen when I removed the tailcone this weekend for priming the juncture before permanently fastening.
The floor panels are 0.025 and all other panels are 0.016 2024T3. The hat shelf rear panel is S-glass/divinycell core panel I made just because I had leftover material from my wingtip project.
Baggage panels weighed
Hat shelf composite panel weighed
Hat shelf fitting
Baggage tunnel with ELT mount
Baggage floor structure
racaldwell
Postby Carlos Trigo » Wed May 20, 2020 6:11 am
Hello Rick
As everybody probably already noticed, I am always copying the good ideas...
Do you have drawings with dimensions of your hat shelf and baggage tunnel panels?
Carlos
Carlos Trigo
Re: Baggage Compartment Weight
Postby racaldwell » Wed May 20, 2020 10:26 am
Carlos,
I do not have drawings with dimensions. I made paper templates with poster board by measuring what I needed for some parts. The C channel structure I made for the baggage floor supports took a second try on a couple of them. I still have to cross my fingers when making a bend that the final lengths come out right.
If you need it, I can take more pictures and send them to you.
Rick Caldwell
Xenos 0057
racaldwell
