Rynoth wrote:Since you're entering the engine mounting phase, I'll add a tip that has been pretty well proven at this point. Include a large washer on the outside of the engine mount bushings, regardless of how the alignment is (add additional washers as necessary for proper alignment.) The bushings WILL start to compress/extrude over time, and the more support they have behind them the better.
http://www.rynoth.com/wordpress/waiex/2 ... ng-issues/
It's a lot easier to add backing washers to the bushings the first time since adding them later either means using a slotted washer or removing the engine entirely to add washers.
Users browsing this forum: dreyn96 and 23 guests
