Share your completed Electrical System Diagrams
A repository of lessons learned from builders with technical guidance and best practices. This is a project of the Sonex Builders and Pilots Foundation.
Forum rules
Lessons-learned submissions follow a standardized format designed to identify the issue, draw out the relevant factors and present useful guidance to others facing a similar situation. The submitter answers the following 5 questions:
1) What went wrong (or right), and why?
2) What were the shortcomings, and why did they exist?
3) What actions were taken to fix the problem?
4) What preventive actions should be taken into account for future efforts?
5) What overall recommendations should be made for future projects?
The length of the write-up and amount of detail presented are left up to each individual. Some lessons learned can be perfectly conveyed in a few simple sentences, while others will require much more. The goal is to be as clear and succinct as possible, not to generate literary masterpieces!
All posts submitted to this forum are held in a review queue for approval by a moderator. Information in the posts will be reviewed, vetted, and modified as needed before going public. Additionally, any replies that are submitted would also be reviewed to ensure they add value and remain on topic. This will avoid normal threat drift of general discussions.
Postby sonex1374 » Mon May 04, 2020 5:44 pm
Sonex Builders,
Share your completed and finalized electrical system diagrams here. Reviewing completed diagrams from other users is an excellent way to prepare a diagram for your own project. Help future builders develop their own diagrams by contributing to this archive.
Rules for posting:
1) Completed diagrams only; no works-in-progress.
2) When posting the diagrams, attach them to your response. Acceptable file formats include pdf, picture formats (jpg, tif, etc), or cad formats (dwg).
3) Add text descriptions if needed. The idea is to create a resource that stands alone.
4) Any questions or discussion that is generated from this thread should be taken to a separate message thread.
5) If changes or additions are needed to the user's original message, please edit that post rather than create a new reply.
Thanks to everyone for contributing!
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Re: Share your completed Electrical System Diagrams
Postby Rynoth » Mon May 04, 2020 6:06 pm
Postby AlexZ » Wed May 06, 2020 10:55 am
Alex
Flying:
Sonex Legacy TD PH-AWX Aerovee https://www.facebook.com/SonexPHAWX/
RV-7A PH-PWP
Building:
Piel CP1320 https://eaabuilderslog.org/?s=CP1320
AlexZ
Postby sonex1374 » Wed May 06, 2020 5:16 pm
Generic Sonex-specific wiring diagrams based on Bob Nuckolls AeroElectric Connection "Z-figures". These have been proven highly reliable and are an excellent place to start your specific design.
Jeff Shultz
Kansas City, MO
sonex1374
Postby mike.smith » Thu May 07, 2020 7:55 pm
Electrical diagram for Sonex with AeroVee 2.1. Landing light, combination position/strobe lights, smoke system, transponder, radio, MGL Xtreme Mini.
https://signaturearchitects.egnyte.com/dl/iIWUy59pqA
Postby sonex1374 » Tue May 26, 2020 11:26 am
Here are a few others to add to the archive that have been previously posted.
Chris Dillman (Waiex # 079): He shows a way to use a traditional key switch (L-R-Both-Start) with an AeroVee. This is tricky because you need to use a dual pole relay to handle both top & bottom magnatrons, plus a second grounding path to ensure the magnatrons are always cold when the system is powered down. It's more complicated than simply using toggle switches, but if you really want a key switch, this is a way to do it.
Chris Dillman Elec Sys2a.pdf
(140.52 KiB) Downloaded 615 times
Chris Dillman Elec Sys2a.dwg
(104.77 KiB) Downloaded 577 times
Jack Lockamy Sonex #300: Simple diagram based on Tony Bingelis Firewall Forward book.
elect_schem_SNX_300.pdf
(47.66 KiB) Downloaded 597 times
David A. Sonex # 1327
Electrical System N109DA-5.pdf
(69.28 KiB) Downloaded 592 times
Jeff
Jeff Shultz
Kansas City, MO
sonex1374
Return to Lessons Learned
