by marsolgp » Wed Dec 24, 2014 10:58 am
Sorry, no photo of the mounting. Plumbing is pretty straight forward, the one top fitting takes a 5/8" hose from the engine crankcase vent. One bottom fitting, also takes a 5/8" hose to overboard, exit the cowl area. And the second bottom fitting is a 1/2" NPT female that I installed a 1/2" NPT to -6 AN fitting and braided -6 hose that drains to the newly installed mini-sump (that contains the new oil filter).
The bottom of the oil separator must be mounted above the engine oil level in normal flight attitude. so it'll drain back into the sump.
Just found a photo: Go to the photo section here on the forum, go down to "SONEX OPEN HOUSE photos - redux" click on the link to Zenfolio in the first post, then go to page 12. on the bottom row is a photo of the bottom LH side of factory turbo engine.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
