by sonex1374 » Fri May 01, 2020 10:49 am
Carlos,
I can't say for sure, but I don't think replacing the actual Azusa 5" wheel hubs is very common on the Sonex. These stock hubs will accept slightly larger tires (5.00x5) that increases overall tire diameter by approximately 2 inches. Replacing tires allows for improved performance on unpaved surfaces (gravel, long grass, etc), and the cost to make this change is minor (approx. double the price of stock tires, and an increase of 2-3 lbs).
If you're looking to use tires larger than 5.00x5, you may indeed need 6" hubs to be able to mount the larger tires. I doubt this is really necessary though.
Jeff
