by builderflyer » Fri May 01, 2020 10:18 am
Michael,
I've had two parts failures away from home........both times a dead ignition coil so definitely carry an extra one of these, along with the tools to make the removal and installation possible (it should be noted that having the recommended 1/2" diameter cold air blast tube aimed at each coil just about eliminates this failure). And, the other times I've been stuck some where has been with a weakened battery. So I always carry a small trickle charger with me...........it has enough cord attached to be able to reach a nearby 110v outlet that always seems to be available on the outside of a hangar or office building. An hour or two of charging has always got me going again.
Have fun with your adventures,
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
