NWade wrote:For those considering a cold air scoop or NACA duct like the one Ryan Roth mentioned:
Remember that if you just add ram air into the lower cowling near the Aeroinjector/carb, you are pressurizing that lower cowling area and likely reducing the pressure drop between the upper and lower plenums - cutting down on the cooling airflow around your engine and past your engine cylinders!
It’s important to keep all of these interrelated systems In mind, and think about how they interact before you jump in to making something that may or may not yield a net improvement.
Take care,
—Noel
Msing48 wrote:Wes, that photo is from the 1st or 2nd “Great Southern Sonex Gathering” in Conroe, Texas. I was very much impressed with what a fine job you did building it. I’m sure your Onex will be just as nice if not nicer.
Users browsing this forum: No registered users and 33 guests
