WesRagle wrote:You will seldom hear an AeroVee pilot complain about cruise performance. The complaint is usually anemic climb rates on hot and high days. During climb the throttle is opened up, the CHTs start increasing, the air speed drops causing airflow through the cowl to decrease, ... So I would argue that during climb the under cowl temperature increase will be maximized. Perhaps the 9% Jeff calculated goes to 12%. In any event, the power will be least exactly when you want/need it the most.
sonex1374 wrote:The bottom of the coffee can is cut at an angle to match the slope of the cowling, while the sides stop approximately 1/2 inch above the cowling to provide a method of air escape to prevent pressure buildup.
Bryan Cotton wrote:If I understand correctly, the concern is differential pressure between the intake area and the top of the tank. We only have so much head pressure and this could be overwhelmed by a large static pressure at the fuel exit in the aerocarb. So it is not just a 1000' equivalent difference, it is delta P impeding the flow of fuel.
Gravity feed will provide about 1.0 PSI for every 30 inches of head.
Users browsing this forum: No registered users and 57 guests
