Arjay wrote: 1. Have any of you guys experienced engine flooding out doing acro? If so, what did you do to cure that problem?
Arjay wrote: 2. Is installation of a fuel pressure regulator necessary?
Arjay wrote:Questions: 1. Have any of you guys experienced engine flooding out doing acro? If so, what did you do to cure that problem?
3. If it is, would it be ok to weld a bracket to the motor mount (cross piece going side to side) to hold the regulator?
Any input you guys have would be appreciated. I am getting too old to keep waiting for my acro fix.
gyroron wrote:Or I will pull too hard and overstress the tail or something.
Rynoth wrote:gyroron wrote:Or I will pull too hard and overstress the tail or something.
Do you happen to have a G-meter? If not there are some apps for phones that can give you a ballpark figure. I never went over 3g's in my loops, and even that felt fairly uncomfortable to my body. I think the plane can handle a lot more G's than I can. Also, G's probably aren't going to stress the tail nearly as much as the main wings. Over-speed on the other hand, might.
If you've never done a loop in any plane though, I'd go back to what Joe said. Find an aerobatic instructor and take some lessons first.
Users browsing this forum: No registered users and 29 guests
