Guarded Switches for Important Systems?
Re: Guarded Switches for Important Systems?
Postby XenosN42 » Tue Apr 07, 2020 3:48 pm
Spaceman wrote:If you kill the engine by shutting all the ignition off, like in the pattern, will it fire right back up when you turn everything back on? Will an Aerovee windmill at pattern airspeed? Honest question, I have no idea!
My AeroVees will start right back up if the ignition systems are turned off. My AeroVees wouldn't windmill or move at all.
-- Michael
OneX N169XE
XenosN42
Postby Spaceman » Tue Apr 07, 2020 4:16 pm
I guess you have a starter to spin it right up if it's not already windmilling...
I'm just picturing the C-130's I fly at work, and I think just about every switch in there that isn't a light or pitot heat is one of these:
So I'm very used to using those. But they are expensive!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby DCASonex » Wed Apr 08, 2020 8:13 am
A guard for your master switch, if it has a cross hole drilled in it provides a place to put that little clip that locks the canopy slide while it also locks the switch off. Keeps the clip from getting lost, while insuring that the master does not get flipped on accidentally.
Postby N190YX » Thu Apr 09, 2020 2:22 pm
switch guard3
Pull to unlock switch.png (17.71 KiB) Viewed 6806 times
switch guard
switch guard.jpg (14.6 KiB) Viewed 6806 times
Having inadvertently turned off the master switch when operating the gear retract switch to retract the gear in turbulence (then wondering why the gear was not retracting), I plan on switch covers or pull to switch type switches for the master and possibly ignition switches if not using the key off left right both start switch. Photos from Aircraft Spruce.
N190YX
Postby Rynoth » Wed Apr 22, 2020 4:54 pm
Your question inspired me, so I tested it today (at a safe altitude next to a runway of course.)
https://youtu.be/CmnEc_UprfM?t=101
I was at 80KIAS when I pulled the mixture and 75KIAS when the prop stopped after about 8 seconds. Mixture in, then immediate restart using the starter motor. Aerovee Turbo with Sensinech climb prop.
Postby WesRagle » Wed Apr 22, 2020 8:39 pm
HI Guys,
Rynoth wrote:I was at 80KIAS when I pulled the mixture and 75KIAS when the prop stopped after about 8 seconds. Mixture in, then immediate restart using the starter motor.
On my AeroVee pulling mixture and turning the ignition off had a totally different effect. In the early stages of my Sonex Phase One I had the idle set too low. The engine died on final and by the time I collected my wits and tried to restart the engine was flooded and would not restart. I glided to an uneventful landing. But, I learned that if the engine dies (ignition turned off) with mixture in on an AeroInjector it will continue to flow fuel and flood.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Spaceman » Wed Apr 22, 2020 8:42 pm
Good to know!! Impressive real world test... Although I don't know how else we'd have gotten an answer!
Chris Paegelow
Spaceman
Postby WesRagle » Wed Apr 22, 2020 9:03 pm
You can play with it on the ground. Just shut the ignition off and leave the mixture in and see how long it takes to flood.
I practiced a procedure that went something like this:
When the engine dies quickly pull mixture to idle cut off.
Engage the starter until either the engine fires (the flood is cleared) or 5 seconds passes (the engine wasn't flooded).
If the engine fires advance the mixture to full rich immediately.
If it doesn't fire advance the mixture to full rich and continue cranking.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Rynoth » Wed Apr 22, 2020 11:47 pm
WesRagle wrote:When the engine dies quickly pull mixture to idle cut off.
Wes
That's essentially what my emergency air restart procedure will be once I complete my flight testing and create a full flight manual. Anyone with an Aeroinjector should be acutely aware that if the mixture and fuel selector are open (and there's fuel in the tank), fuel IS flowing, regardless of whether or not the prop is turning or if the aircraft is sitting on the ground.
I'm not going to flight-test flooding my engine, I did think it was important to know how my engine windmills (or not) and could demonstrate it with appropriate safety margins. The flooding aspect is very relevant though, and I can recall a couple fairly recent topics on this forum where too much fuel has been an issue that stopped an engine, such as fuel leaks, aerobatics, inadvertent ignition cutoff or low idle.
Postby WesRagle » Thu Apr 23, 2020 11:15 am
Rynoth wrote:I'm not going to flight-test flooding my engine,
Me neither. Once was one time too many.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Return to Panel
Users browsing this forum: No registered users and 36 guests
