- bad faceplate on KX155
The faceplate lense of my King KX155 was crazed and looking bad, so my local avionics shop recommended I obtain a replacement faceplate lens insert from Aircraft Engravers in Granby, CT, they said Aircraft Engravers is reasonable compared to Bendix King to obtain replacement faceplates for my KX155. While the gas discharge numbers of my KX155 worked fine and were legible, the faceplate on the right side was bad and needed replacement, see attached photo. Replacing the faceplates is an easy thing to do, just remove the radio, remove two screws on each side of the front, and replace the faceplates.
Their internet site shows faceplates, lenses, etc. for numerous radios and instruments. Interestingly, you have to call them to place an order, you can't order from their internet site after you find what you need. If you have any unsightly (or worse condition) faceplates for any common radio or other instruments, this is an option to fix it!
See:
https://www.engravers.net/index.html
