by MichaelFarley56 » Thu Sep 26, 2013 11:24 am
Hey Keith, good call on not using silicone on soon to be painted surfaces! I wonder if graphite powder is also as bad, or if it's easier to clean? I used that a lot on my cowling hinge pins and it worked well. I'm sure you did it, but when you get the pin out make sure you take the pin to a grinder or scotch brite wheel and taper the tip to a point. That will make it much easier to insert and/or remove next time.
I can't count the number of times I was so frustrated during my build I wanted to take the nearest tool and throw it as hard as I could. At that point it was time to call it quits, enjoy a nice adult cold BEvERage, and regroup. Things are always much easier afterwards.
Frank also has a great idea! I did that same thing in a few places.
Waiex #0056 - N569KM (sold)
Onex #245
