by rk2436 » Sat Sep 21, 2013 12:09 am
You can use music wire from a local hobby shop.I forgot the exact size needed but is's easy to find the correct one. I used a smaller size on the lower cowl hinge and copied Gus S 's idea of putting it in from the bottom and going right thru the cooler opening to a small section of hinge riveted to the area where the plans show a south co.
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
