Postby Rofomoto » Thu Mar 26, 2020 11:57 am
Exhaust and intake calls cut for Cowling
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Mar 29, 2020 1:34 pm
So now I’m doing the leak test on my fuel tank before final installation. It sat for 24 hours filled with water and I see none. Do you think that’s good enough or should I fill with fuel to be sure?? Thanx billy
1735
Longassproject
Rofomoto
Postby pappas » Sun Mar 29, 2020 4:58 pm
I would do a pressure test. Not more than 5 lbs per square inch. Ad check with the factory to make sure that 5 lb psi spec is accurate. If it doesn't leak over a 24 hour period you are good to go.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Rofomoto » Sun Mar 29, 2020 5:42 pm
pappas wrote:I would do a pressure test. Not more than 5 lbs per square inch. Ad check with the factory to make sure that 5 lb psi spec is accurate. If it doesn't leak over a 24 hour period you are good to go.
Thanx.
1735
Longassproject
Rofomoto
Postby sonex892. » Sun Mar 29, 2020 6:22 pm
5 psi might even be on the high side for a welded tank. The RV guys test their prosealed tanks by taping on a rubber glove to test for leaks, the inflated rubber glove is used to set the inflation pressure and it's also used as the leak indicator.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rynoth » Sun Mar 29, 2020 7:14 pm
I did a 24 hour balloon test, attached to the fuel vent fitting:
The balloon didn't shrink in 24 hours, and my fuel system hasn't leaked yet (well, not at the fuel tank anyway.)
Postby Rofomoto » Sun Mar 29, 2020 8:04 pm
Steve
Sonex 892
Do you think the pro seal is necessary if no leaks can be found?? Always worried if that stuff breaks down and clogs the screen. I’ve used tank sealers on motorcycle tanks that have broke down.
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Sun Mar 29, 2020 8:36 pm
RV tanks are riveted structures and pro-seal is required. Not for our tanks. I also used a balloon like Ryan.
Postby Rofomoto » Sun Mar 29, 2020 8:41 pm
Bryan Cotton wrote:RV tanks are riveted structures and pro-seal is required. Not for our tanks. I also used a balloon like Ryan.
Than Bryan but I made my tank welded aluminum no rivets. So that’s why I’m asking.
1735
Longassproject
Rofomoto
Postby GordonTurner » Sun Mar 29, 2020 8:44 pm
Use the balloon technique. 5 psi is say too much.
Return to Photo Album
