Is 18 Degrees Up Elevator OK for Onex?
Postby gcm52 » Wed Mar 25, 2020 12:33 pm
I am grinding the elevator stop but it seems like it is going to be very difficult for me to get more than 18 degrees up elevator on my Onex. Is this OK? Have others gone with this amount of up elevator? I would be especially interested in hearing about anyone flying with 18 degrees of up elevator and if gives enough up elevator authority. Thanks.
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: Is 18 Degrees Up Elevator OK for Onex?
Postby Mike53 » Wed Mar 25, 2020 5:39 pm
This is what Kerry had to say about it.
Hi Mike,
The Onex is good with a minimum of 18 degrees up travel and 22 degrees of
down travel.
Sonex Aircraft Tech Support
Sonex Aircraft LLC
511 Aviation Road
Oshkosh, WI 54902
Tech Line: (920) 230-TECH (8324)
Mon, Wed. and Fri. 10 AM to 12 AM and 2PM to 4PM CT
Orders and General Info:
Ph.920-231-8297
Fax (920) 426-8333
http://www.sonexaircraft.com
Please use the following e-mail addresses to Contact Sonex Aircraft:
Sales Info: sales@sonexaircraft.com
Orders: orders@sonexaircraft.com
Accounting: accounting@sonexaircraft.com
Tech Support: tech@sonexaircraft.com
Mike
Antoine de Saint-Exupery
Mike53
Postby gcm52 » Thu Mar 26, 2020 9:54 am
Thanks Mike!
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Postby Gordon » Thu Mar 26, 2020 10:21 am
Onex Up Elevator Travel....?
Hey George......my Onex is flying with 19 degrees up travel. That seems to be adequate. What I DID discover while practising stalls (at altitude) with 25 degrees (half flap) I could get a clean stall. With full flaps it really wouldn't stall but kind of mushed along, bobbing up and down (makes for a strange ride!).
Years ago I owned an Ercoupe that was "stall proof" and this had a similar feel when trying to stall it.
I have found no negative results during the landing flair with 19 degrees up elevator....of note: I much prefer to land with half flaps after much experimenting with half and full flaps...…..your mileage may vary.
I have some photos of the modified elevator horn and if you want them you will have to email me for that.
gdbaxter78@gmail.com
Gordon...…...Hummel 2400......Onex C-IODB
Gordon
