Bryan Cotton wrote:Carlos,
Look carefully at the print. Some of the callouts will be for rivets, and some for holes. Assuming the Xenos is like the Waiex, the big Y fitting is riveted to the fuselage, and the stabilizer is riveted to the big Y fitting. The ruddervator hinges go on last. This is by memory from years ago, so use my recollection to help interpret the plans.
Rynoth wrote:It's definitely in the plans in the details somewhere. Again assuming it's like the Waiex tail, basically you don't want rivets where the Y-fitting will interface with the stabilators.
If you look closely in this pic you can see where my y-fitting fits (and isn't yet riveted), as well as the piano hinge/skin rivets in that area that would interfere with pulling the y-fitting rivets.
Carlos Trigo wrote:
So the y-fitting (still not known to me, I only have the tail plans...) is fixed to the aft spar of the Stabilator, right?
Therefore it seems that the stabilator skin rivets which cannot be installed now are the ones that grip the skin to the aft spar, upper and bottom, right?
Bryan Cotton wrote:Here is a good picture of the Y fittings. This is one of my favorite pictures from my build.
Rynoth wrote:
I don't recall this being at all ambiguous in the Waiex plans, but I've never seen the Xenos plans. If it does read the same as the Waiex plans, this may be an opportunity to learn how to read and understand the plans going forward (I'm not being sarcastic, I had many "aha" moments when I realized what the plans were trying to tell me, and this helped for the rest of the build.)
