Stabilator fiberglass tip too long
Postby Carlos Trigo » Thu Mar 19, 2020 1:06 pm
Guys
I am now installing the fiberglass tip in the stabilator of my XENOS, and despite moving it in the most forward position, it is longer than the length of the stabilitor plus the ruddervator assembly.
Longer around 3/8”.
Did anyone have this problem?
Did you leave it like that?
Or did you cut the trailing edge of the fiberglass tip and redo it (lots of nasty fiberglass work )?
Carlos
Enviado do meu iPhone usando o Tapatalk
Carlos Trigo
Re: Stabilator fiberglass tip too long
Postby Mike53 » Thu Mar 19, 2020 5:26 pm
Had the same issue with the Onex. Simply cut a strip from the open end which will automatically shorten it.Assuming it's like the Onex's
Cheers.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Postby scotttro » Thu Mar 19, 2020 5:30 pm
I'm working on an older Waiex. Yes, I had that problem. Did what you said - cut off the tip, subtracted the extra, stuck it back on. Here's a pic of it post-trim.
scotttro
Postby Bryan Cotton » Thu Mar 19, 2020 5:53 pm
I think I did like Mike. Trimmed the bottom. Because of the swept leading edge, it moved the tip forward.
Postby Carlos Trigo » Fri Mar 20, 2020 7:51 am
scotttro wrote:I'm working on an older Waiex. Yes, I had that problem. Did what you said - cut off the tip, subtracted the extra, stuck it back on. Here's a pic of it post-trim.
Scott
The photo you posted seems to be before trim, still with the line where you cut it.
Is this correct?
In that case can you please post the post-trim picture?
Carlos
Carlos Trigo
Postby Carlos Trigo » Fri Mar 20, 2020 8:00 am
Mike53 wrote:Had the same issue with the Onex. Simply cut a strip from the open end which will automatically shorten it.Assuming it's like the Onex's
Cheers.
Mike
This seems to be a good idea, avoiding the nasty fg work of rebuilding the tip trailing edge.
As soon as I get to my shop, I will check if the XENOS tip is tapered, like the Onex’s.
But in this case, cutting a strip along the fiberglass tip, it will shorten up the whole stabilator assembly.
Is there no problem for the aerodynamic design by that stabilator length reduction?
Carlos
Carlos Trigo
Postby Carlos Trigo » Fri Mar 20, 2020 8:07 am
Scott
Is this correct?
Carlos
Scott
Now that I looked better to the picture you posted, I think I saw that you didn’t cut the trailing edge.
You did cut the tip where the blue is, eliminated the extra length, and then just glued the cut piece again.
Am I correct now?
Carlos
Carlos Trigo
Postby Bryan Cotton » Fri Mar 20, 2020 9:23 am
Carlos Trigo wrote:Is there no problem for the aerodynamic design by that stabilator length reduction?
Carlos
Carlos,
I don't think the loss of span is significant. It might have been a half inch. You can always check with Sonex.
Postby scotttro » Fri Mar 20, 2020 2:00 pm
Carlos Trigo wrote:
Scott
Is this correct?
Carlos
Scott
Am I correct now?
Carlos
The picture I posted was after trimming. I cut off the rear-end far enough forward that I missed the extra -thick layup at the back. Then I trimmed a half an inch or so off the forward section and reattached the rear. Smoothed the inside a bit with some coarse paper, several layers built up inside, job was done. The radius on the "outermost" curve is pretty constant at that point, I had very little forming of the 'glass after rebonding them together.
scotttro
Postby Carlos Trigo » Fri Mar 20, 2020 3:24 pm
The picture I posted was after trimming. I cut off the rear-end far enough forward that I missed the extra -thick layup at the back. Then I trimmed a half an inch or so off the forward section and reattached the rear. Smoothed the inside a bit with some coarse paper, several layers built up inside, job was done. The radius on the "outermost" curve is pretty constant at that point, I had very little forming of the 'glass after rebonding them together.[/quote]
Thank you Scott
Now I got it clear what you did
Carlos
Carlos Trigo
Return to Xenos
