lgsievila wrote:Hi Sam,
AN 525-10R screws are 3/16" (.187). To get a tight fit you consider an undersize drill bit ,#13 and then use a 3/16" straight reamer. Not sure of the exact location you are talking about but if the screws are in shear, you don't want any slop at all in the hole.
lgsievila wrote:Hi all,
Ryan-you are correct, any time you want a body fit bolt/screw you should drill undersize and then ream to the correct diameter. Sonex 892, I would be concerned about the 1 in ten times your drill action is oversize. When you use a reamer the attachment hardware acts as a dowel and that is what you want in a shear application-you don't want anything to move. That is also why you never use a threaded fastener in a shear application-reference Service Bulletin SNX-SB-008.
EAA Tech Councilor
Users browsing this forum: Google Adsense [Bot] and 26 guests
