GraemeSmith wrote:The cylinder leak down test is a pretty crude tool. Mechanics like Mike Busch have made a case for much of the data we get from EFIS type monitoring as being much more useful. None the less the Condition Inspection in the US requires a leakdown test via FAR Part 43 D
GraemeSmith wrote:Robbie - 43 D (d) 3
Mel wrote:43D does require a compression test. It does NOT specify a specific method of performing the test.
Sonex1517 wrote:Mel wrote:43D does require a compression test. It does NOT specify a specific method of performing the test.
Thanks Mel!
Does our condition inspection legally fall into the same FAR?
GraemeSmith wrote:Mel wrote:43D does require a compression test. It does NOT specify a specific method of performing the test.
The other method I'm aware of is to put a pressure gauge directly into a spark plug hole and crank the engine with the mags off and see what the highest sustained reading is. But the answer is usually somewhat transient as the pressure is being provided by the cranking and quickly falls off if there are problems. Leaving you little time to listen at inlet, exhaust and crankcase to try and figure where the issue is.
Any other method? Like Robbie - genuinely curious...
Mel wrote:GraemeSmith wrote:Mel wrote:43D does require a compression test. It does NOT specify a specific method of performing the test.
These are the only 2 practical methods that I'm aware of. The method you describe tells the overall condition of the cylinder, but the leak down method is the only way I know of that allows further trouble shooting. OTOH, the leak down method does not tell you the condition of the cylinder below TDC.
Users browsing this forum: Bing [Bot] and 52 guests
