Postby Rick524 » Sun Jan 12, 2020 10:30 pm
Hi Billy, I'll make up a pin to pin diagram for you, but probably will be
tomorrow. The main thing is to get the data lines straight, like encoder lines a1, a2, a3 etc
to the corresponding transponder inputs. Then power and ground. Most other lines
aren't used.
I'll cipher it out in the AM.
Rick
Rick524
Postby Rofomoto » Sun Jan 12, 2020 11:16 pm
Rick524 wrote:Hi Billy, I'll make up a pin to pin diagram for you, but probably will be
aren't used.
Rick
Can’t thank you enough. Bin looking at this way to long.
1735
Longassproject
Rofomoto
Postby Rick524 » Mon Jan 13, 2020 2:40 pm
Hi Billy, I sent a diagram of the parallel cable to your email address, I think this will work for you.
With the SS120 and GTX327 you also have the option to use a serial connection between the two.
This may be easier due to only needing 1, RS232 signal line and ground. I'll do another
diagram using the serial connections and send it later today.
Rick
Rick524
Postby Rofomoto » Mon Jan 13, 2020 7:28 pm
Rick524 wrote:Hi Billy, I sent a diagram of the parallel cable to your email address, I think this will work for you.
Rick
Thanks again Rick
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 17, 2020 8:00 am
Wow...do these weekly 200.00 orders to aircraft spruce ever end!!! Haha all the small stuff sure adds up. Controls,wiring,ads-b are all things that must be done but every day not much satisfaction like seeing a large part done. All my big parts have bin done for months.
Also, has anyone run wires through spar tunnel at the far outboard lower point on the tunnel? There seems to be a gap there when wings are attached.
1735
Longassproject
Rofomoto
Postby Area 51% » Fri Jan 17, 2020 11:49 am
That's where it calls out on the print (page L-05 view EE and FF) to pass the brake cables through on a trisickle. Our trim cable went through that gap.
Postby Rick524 » Fri Jan 17, 2020 12:56 pm
Hi Billy, I ran my coax cable and another bundle of wire under the left side and
a bundle of wire to the ELT and strobe box under the right side. I wrapped them
in spiral wrap for protection.
Rick
Rick524
Postby Rofomoto » Fri Jan 17, 2020 1:06 pm
Thanx guys. My battery is behind the baggage department so I was thinking of running 4awg through there.
1735
Longassproject
Rofomoto
Postby sonex892. » Fri Jan 17, 2020 7:31 pm
All my wiring runs under the spars there Billy.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rofomoto » Thu Feb 20, 2020 10:01 am
1735
Longassproject
Rofomoto
Return to Photo Album
