Rick524 wrote:Hi Billy, I'll make up a pin to pin diagram for you, but probably will be
tomorrow. The main thing is to get the data lines straight, like encoder lines a1, a2, a3 etc
to the corresponding transponder inputs. Then power and ground. Most other lines
aren't used.
I'll cipher it out in the AM.
Rick
Rick524 wrote:Hi Billy, I sent a diagram of the parallel cable to your email address, I think this will work for you.
With the SS120 and GTX327 you also have the option to use a serial connection between the two.
This may be easier due to only needing 1, RS232 signal line and ground. I'll do another
diagram using the serial connections and send it later today.
Rick
Also, has anyone run wires through spar tunnel at the far outboard lower point on the tunnel? There seems to be a gap there when wings are attached.
