Spaceman wrote:I bet if you had the floor clecoed on when you pilot drilled the turtle deck skin to the upper longerons, then took the floor off to install the formers, then reinstalled the floor before you updrilled everything you'd be totally fine. I really don't think the turtle deck by itself would be rigid enough to tweak the whole fuselage unless you really tried to mess it up.
pappas wrote:Funny story that has probably been told before. I visited the Sonex factory in 2006 when I was thinking about building my first Waiex. I asked John about that turtledeck fitting under the fuselage side skin. I thought if it was outside the water would not get in as much. His answer to me was "Water gets in everywhere, it also gets out everywhere". So... do it the way the plans say and don't think too much!
