by Rynoth » Wed Jan 15, 2020 10:03 am
For what it's worth, I took off my lower aft skin after updrilling and set it in the corner of my basement (and then the corner of my hangar) for 3 years/1200 build hours. The only time it went back on the plane was when I joined the forward/aft fuselage together to up-drill rivet holes to the fwd fuselage floor, after which I took it right back off. I did my turtledeck, put the plane on wheels, hung the engine, rigged the wings, installed/rigged my stabilators/rudder/flight controls, moved the plane to the hangar etc etc all with the aft fuselage floor off, and when it came time to finally attach it at the end of the build it fit just like it did 3 years earlier.
I wouldn't worry too much about losing your "square" aft fuselage by removing the floor as long as the rest of the tail cone box is riveted up.
Rynoth on Wed Jan 15, 2020 10:47 am, edited 1 time in total.
