by builderflyer » Mon Jan 13, 2020 11:10 am
Mark, I'm no expert either and you don't say what your engine serial number is..........but if it is close to mine I'll offer a word of caution on setting the 0.010" clearance between the ignition coils and the magnets on the flywheel. When my engine was manufactured by Jabiru in 2001, they didn't true up the magnet distance from the center of rotation as they did on later engines. So when setting the 0.010" clearance you have to first determine which of the 3 sets of magnets is the critical set.......the set that will give you the tightest clearance to the ignition coils. Then, once you have that determined, verify which of the 3 magnets in that set of magnets gives you the tightest clearance to the ignition coil and use that one to set the 0.010". Also, use a felt tip pen to color all of the magnets on the flywheel on the edge facing the ignition coils. That way if you ever you have a magnet nicking an ignition coil, you'll see where the pen marking has been disturbed before you run your engine too long this way.
Setting the ignition coil to magnet clearance on these older engines is a real pain but well worth the effort to get it right or at least to avoid interference between the two.
One more thing.........except for spark plugs and an occasional ignition coil when it has burned out, I've not replaced any other components on my 19 year old engine. Well, a couple of years ago I did replace a tired old Aerocarb with a new Aeroinjector.
Hope this is of some benefit to you,
Art,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,Jabiru 3300 #261
