rick9mjn wrote:here is just my .02 cents idea;
if you can, try to use the fuses with the "fuse blown LED inside" in your fuse block, they do cost more , but in the future " if you blow a fuse " , the extra money will be well spent
quote of the day ;"Murphy was an optimist." - Anonymous
good day / rick
sonex1374 wrote:Billy,
Yes, the Odyssey can be mounted on its side. Its a sealed battery and won't leak.
I think you need to re-look the crowbar control of the voltage regulator disconnect relay. Although the diagram doesn't label any of the relay terminals (so I can't be sure), it appears that the crowbar is *not* connected thru a fuse. This is a problem because if the crowbar detects over-voltage and "activates", it connects the positive and negative wires together in a "dead-short". This dead-short is designed to pop a breaker or burn out a fuse. Without one in place, it will burn up the smallest wire it can find, probably the crowbar module itself.
Jeff
Your diagrams show an extra jumper wire connecting the coil (top terminal) with the NO terminal (the one coming from the capacitor). This isn't needed, and in fact will cause the 2 amp fuse to be effectively removed from the circuit. Think about how energy will flow from the capacitor to the OV module to ground and you'll see that with that jumper in place it won't actually go thru the 2a fuse. In this case, the OV module wires themselves will ultimately act as the "weak link" or fuse once the module activates. You either need to remove the jumper or add a fuse/circuit breaker somewhere to the run between the capacitor-relay-OV module.
Jeff
