by Darick » Mon Dec 02, 2019 10:06 pm
This could be an interesting discussion with Jim Weir. Conventional wiring is battery positive-switch-appliance-ground which assumes the electron flow is from positive to negative. However in Jim's article in the August issue of Kitplanes, he says "...those electrons are coming from the negative pole of your battery up through the radio and out into the positive bus."
It's black magic to me but I'm sticking to the conventional method of wiring.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
