dbdevkc wrote:That's exciting. Hey - can you take a look at your oil pan bolts - are they drilled so they can be safety wired? I don't recall if mine were or not and I am reading through the assembly manual again and I see WW states they use drilled head bolts for that reason.
rick9mjn wrote:do ""not"" put a switch on the ground side of the schematics for radios,,,,,,because it will not work ,because the radio also gets a ground from the antenna ......also switching the ground is not the standard way of doing thinks on a airplane or a car,,,,,,,,in fact, i think,the only thing "in a car" that is done way ,is the dome light switch......
......also coming from the fuse, to the no-off switch , the standard wiring way to do things....
just my.02 cents idea....
good day..../rick
Area 51% wrote:Unless I've read the schematic wrong, switching the ground is exactly how a master contactor is activated.
Users browsing this forum: Google [Bot] and 3 guests
