by sonex1678 » Fri Nov 22, 2019 12:58 pm
SonAl:
I didn't see any responses to your question posted on 9 Nov, so thought I would chime in late. I had one flap completed as an A model flap before I started my conversion, so I removed the existing inner most rib with the flap drive bracket, drilled lightening holes in the removed rib, and reinstalled it without the bracket. I then installed an additional rib with the new B model flap drive bracket per the b-model plans, which, as you indicated, is slightly inboard of the A model inner most rib. Finally, I cut a small sheet metal plate to install on the front of the new B model rib and bracket to fill the cutout where the A model bracket had protruded forward from the flap.
I built the remaining (second) flap per the B model plans, but added an additional rib where the A model inner most rib would have been to ensure both flaps were identical. The additional rib was lightened and drilled exactly like the one in the other flap, again to ensure both flaps were identical.
For reference, you can look at my Kitlog Pro Log at "http://www.mykitlog.com/scripture" looking specially at the postings from 2/28/17 and the postings around that date. Looking at the log, I am very behind in updating it but think what you are interested in is there. Hope it helps....
Douglas B Scripture
Sonex 1678
