Postby samiam » Wed Nov 20, 2019 8:36 pm
Hey Billy - lookin' good!
My offer still stands - give me a hollar when you're ready for a hand getting the engine in place.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby EdW » Wed Nov 20, 2019 11:34 pm
Did anyone else notice the 'fat pill' (donut) box on the bench? Where's the coffee?
EdW
Postby Rofomoto » Thu Nov 21, 2019 12:17 am
dbdevkc wrote:That's exciting. Hey - can you take a look at your oil pan bolts - are they drilled so they can be safety wired? I don't recall if mine were or not and I am reading through the assembly manual again and I see WW states they use drilled head bolts for that reason.
Mine are not drilled
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Nov 21, 2019 5:34 pm
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Nov 25, 2019 9:32 pm
Access panel for Corvair ignition to be mounted behind firewall
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Dec 02, 2019 9:50 am
I have maybe a dumb question... trying to figure out my wiring and am wondering if I can put a switch on the ground side of the schematics for radios so to turn them on at one time. Transponder, com radio and echo adsb. Thanks billy
1735
Longassproject
Rofomoto
Postby rick9mjn » Mon Dec 02, 2019 10:23 am
do ""not"" put a switch on the ground side of the schematics for radios,,,,,,because it will not work ,because the radio also gets a ground from the antenna ......also switching the ground is not the standard way of doing thinks on a airplane or a car,,,,,,,,in fact, i think,the only thing "in a car" that is done way ,is the dome light switch......
......also coming from the fuse, to the no-off switch , the standard wiring way to do things....
just my.02 cents idea....
good day..../rick
rick9mjn
Postby Rofomoto » Mon Dec 02, 2019 10:53 am
rick9mjn wrote:do ""not"" put a switch on the ground side of the schematics for radios,,,,,,because it will not work ,because the radio also gets a ground from the antenna ......also switching the ground is not the standard way of doing thinks on a airplane or a car,,,,,,,,in fact, i think,the only thing "in a car" that is done way ,is the dome light switch......
good day..../rick
Rick. Thanx
1735
Longassproject
Rofomoto
Postby Area 51% » Mon Dec 02, 2019 1:13 pm
Unless I've read the schematic wrong, switching the ground is exactly how a master contactor is activated. Many of the relays on my 2008 Colorado are also ground-to-activate. Keeps the "hot" wire short in length, and if the wire to the switch does chafe through, no unscheduled blank screens.
Separate ground activated relays for the avionics and voltage regulator is the direction I'm taking.
Area 51%
Postby Rynoth » Mon Dec 02, 2019 5:17 pm
Area 51% wrote:Unless I've read the schematic wrong, switching the ground is exactly how a master contactor is activated.
The switch FOR the master contactor solenoid is to ground (little wire). The path you are closing when the contactor is energized however (big wire) should be the positive from the battery.
Return to Photo Album
