Inline fuel filter location
Postby petep » Wed Nov 13, 2019 5:26 pm
Where are people installing an inline fuel filters for a Aeroinjector system?
1. Forward of the firewall
Pro - easy access
Con - Heat soaking
2. Aft of the firewall
Pro - Less heat soaking
Con - Hard to access.
Pete
petep
Re: Inline fuel filter location
Postby Bryan Cotton » Wed Nov 13, 2019 5:58 pm
I considered in the cabin. Problem was getting it to fit while keeping a downhill run and not interfering with the pedals. I have a super short run if you check out my posts in my Cotton Waiex 191 thread.
Edit: read page 102 forward.
viewtopic.php?f=39&t=578&start=1010
Postby mike.smith » Wed Nov 13, 2019 6:53 pm
Mine = Firewall / Gold Cube fuel sender / fuel filter / short fuel line / AeroInjector.
I have the entire fuel system double insulated from the firewall to the AeroInjector, including the Gold Cube and the filter.
Postby Darick » Wed Nov 13, 2019 9:46 pm
See page 11 on my photo album.. all items are inside the engine compartment...
firewall-fuel drain-fuel filter-red cube-tee for burp tube-carb
At this time I only have fire sleeve from the red cube to the carb. I haven't done much flying in hot weather and so far I've had no burb issues.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
