by SonexN76ET » Wed Oct 30, 2019 8:29 am
John,
While it is prudent to have your propeller balanced by professionals if you suspect an imbalance you personally will need to know how to properly track your propeller as it is something that needs to be checked each time you torque your propeller at each 25 hour oil change. Tracking and checking the propeller tracking is not difficult. Below is a useful link that documents the procedure in plain language and sufficient detail:
http://www.ultralightnews.com/pilotslounge/propellertracking.htmEAA also has a video in their “Hints for Homebuilders” series that graphically depicts the tracking process.
Jake
Sarasota, Florida
